Hi,
I'm driving a 78 Volkswagen Bus (2 liter air-cooled, hydraulic cam). I'm in LA. 50 degrees is a cold day. My oil temps are usually 180-210F. This is the Type IV engine which has a real oil-filter.
I've been using 10W-30 Dino oil (various brands, cheap) and changing about every 3000 miles. The owners manual from 1978 recommends 30 weight but that was before multi-weights were reliable (from what I heard).
I want to have good engine life, MPGs. The oil is also used for conducting heat away from the heads, so if there's anything that makes that work better (?) I'd be interested.
What do you recommend? Should I be using synthetic or diesel oil or?
Thanks,
Mark
Thanks,
Mark
