Lately a few people have been commenting about ring sticking and the correlation to using ester based oils!!! Is this true and if so, is GC in that category?
LOL! yes, send me all your Redline...quote:
Originally posted by bigpaulo:
Yes, ester based oils are horrible... they give terrible UOAs, they absorb water, and they accelerate soft metal bearing wear.
(1 ticket, first class please!)
PAO is not necessarily made from petroleum. The primary source for PAO is ethylene gas. ExxonMobil produces ethylene using ethane separated from natural gas. Other companies produce ethylene by cracking petroleum products. Among other things, ethylene gas is used to gas green tomatoes to make them red.quote:
Originally posted by Bob Woods:
PAO cause seals to shrink, Esters cause seals to swell, with the correct blend synthetic oils will not cause seals to fail. Aircraft turbine engines use ester based oils but they also use specially made seals and gaskets. Typically synthetic automotive oils have 90-98% PAO's with the rest being mineral oils and ester with some additives making up less then 25 by volume. Syn-blends average about 50% PAO's and the rest being mineral and base additive package. For those of you that haven't heard it, PAO IS A PETROLEUM PRODUCT. IT IS MADE FROM HYDROCARBONS. IT IS NOT A PRODUCT OF COOKING OIL RECYCLING.
