I have an 03 Chevy Tracker and on really cold days I get a fairly high pitched noise from the front drivetrain. Not a grinding but pitched a bit lower than a cop car siren. It goes away after 1/2 a mile so I think the problem is "cured" once things warm up slightly.
There is also lots of friction as sometimes I need to use 4wd to go up the hill on the drive way as the back tires don't have enough grip to over come the front axle friction when driving on snow.
Any chance they spec'd grease to thick for -20C? The wheel bearings seem perfect otherwise, no play or sounds and only 60,000 miles on them. Another fellow with an 03 tracker has the same issues, dealer was useless of course.
Ian
Ian
