Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
What the..
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
36 registered members (A_A_G, AurionX2, BillyE, Aichiguy, AZjeff, Bjornviken, 5 invisible), 604 guests, and 16 spiders.
Topics297,572
Posts5,118,224
Members69,899
Most Online3,589
Nov 2nd, 2019
Need Valve Clearance Specs-B&S 18.5 Intek #1192115 07/12/08 08:53 AM
O
olddognewtrks Offline OP
O
I have a v-twin B&S 18.5 hp Intek. Bought new in 2000. My manual has run off and hid. Silly manual. I know the Exhaust spec is .004-.006, but I need to confirm the Intake. I think it's .003-.005, but I don't remember. Anybody out there know for sure?
Old enough to know better, gettin' past too young to care. Darn it!
Re: Need Valve Clearance Specs-B&S 18.5 Intek [Re: olddognewtrks] #1192129 07/12/08 09:27 AM
O
O
Hey gang: I found the spec on the B&S site. Had to look high and low for the proper number hiding on the engine. Thanks anyway. Now I'm gonna tune it up and go mow my weeds in the great outdoor sauna. Oh joy.
Re: Need Valve Clearance Specs-B&S 18.5 Intek [Re: olddognewtrks] #1192476 07/12/08 08:56 PM
J
JTK Offline
J
Congrats on that! You're the 1 in 1000 owners who would actually check/adjust the valve lash. Prolly a good thing to do. That, or buy a Kohler with hydraulic lash adjusters.
Joel
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Need Valve Clearance Specs-B&S 18.5 Intek [Re: JTK] #1192682 07/13/08 08:12 AM
daman Offline
What are the specs so if someone else is looking they'll know??
"Always"....Mobil 1
Current fill: AFE 0w30
Re: Need Valve Clearance Specs-B&S 18.5 Intek [Re: daman] #1192767 07/13/08 12:17 PM
B
Bill Kapaun Offline
B
It depends on the engine.
Best thing to do is look in the owners manual.
If you don't have one, you can down load one from the Briggs website.
http://www.briggsandstratton.com/maint_repair/manual_and_more/
The OHV engines usually have the valves set with the piston 1/4" PAST TDC to take the compression release out of the mix. That's as important as the actual setting.
Re: Need Valve Clearance Specs-B&S 18.5 Intek [Re: Bill Kapaun] #1193909 07/14/08 09:15 PM
O
O
Bill: Thanks for the reply.
Just to show that no good deed goes unpunished.....I changed my terribly cracked fuel lines, too. Must have knocked a bit of dirt loose, 'cos my float needle stuck open, and drained half a tank of gas into my engine over night. Well, it needed an oil change soon anyway. Came out REAL watery on a cold engine. FINALLY got the stuck float bowl screws loose, cleaned everything out, and now it runs great. Oh, and the intake spec is .004-.006, just like the exhaust. Sounds less clattery now.
Re: Need Valve Clearance Specs-B&S 18.5 Intek [Re: olddognewtrks] #1194632 07/15/08 06:50 PM
B
Bill Kapaun Offline
B
There seems to be 2 different settings for the Briggs OHV engines, depending on the Model#.
.005" +/- .001" both valves and .003" intake & .005" exhaust +/- .001".
