I would read this article:
http://www.gates.com/brochure.cfm?brochure=2822&location_id=2877
Which states:
We have in previous articles
pointed out that today’s coolant inhibitor
packages contain a small amount
of copper-brass protection, but may
provide little protection if a radiator is
made with high-lead solder. Results of
industry standard tests of the new Toyota
extended-life coolant now show a
substantial weight loss (corrosion), both
in a 50-50 mix and in a 33% coolant
mixture (solder corrosion is much
greater in this more diluted solution).
If you have to change a radiator or
heater core, use aluminum. Or, if it’s an
older car and the owner wants the lowest-
cost radiator, you might procure a
soldered-together copper-brass unit.
Conventional American coolant should
provide better protection against solder
corrosion, which can result in radiator
tube restrictions and leaks. But no
coolant provides perfect protection.
If you’re replacing aluminum parts on
an engine, such as a water pump or even
a new cylinder head, remember that
part’s coolant passages have not been
protected. In those cases you should
perform a complete coolant exchange.
Then....go with your gut instinct.
