Your network setup
lain, I think you mean layer 3.
Quite.
Thanks.
Reckon you can't correct things any longer on this site, otherwise I would sort it.
Quite.
Thanks.
You are quite welcome. Yes, there's an edit time limit.
Originally Posted By: Colt45ws
Nice network set-up, mate.
My network is similar except I'm running Cisco RV220W gateway to SG-300 switch in level 3 mode.
Switch configuration setup:
  • VLAN1 - Default
  • VLAN2 - Reserved
  • VLAN3 - Normal Office Use
  • VLAN4 - Trunk line to 3Com 1000-Base-T swich in cinema room for streaming online media
  • VLAN5 - VoIP use
All wired of course for security reasons, by CAT6 ethernet cable.
Thanks!
I like the way that is setup. Putting VoIP on its own VLAN is probably a good idea.
The "Colt45" Wireless is secured with WPA2-EAP-CCMP using RADIUS server on Sarah. "Colt45-guest" is WPA-PSK-TKIP/CCMP with a MD5 hash as passcode.
