I did a bit reading about this product and it seams that it has big following worldwide with quite favorable results.
Has anyone on this forum used their product in engine, transmission or power steering?
Did it work as advertised? What is your take on it?
Their claims:
Problem:
As soon as a mechanism goes into operation, it begins wearing out. Heat and friction strip metal particles from load surfaces and parts wear out. Mass produced parts cannot be made to exact tolerances, which adds to the problem.
What is XADO Gel?
* XADO is a revolutionary engine treatment capable of improving overall car performance. Its unique qualities make it good auto maintenance, and when needed, it can virtually perform an engine rebuild. XADO has been used for years in Europe and is now being introduced to the United States.
Why should I buy XADO?
* XADO saves fuel and energy
* XADO results in noticeable improvement in engine performance
* XADO extends the life of moving parts by two to three times
* XADO provides economical car repair with no down time
* XADO is good for the environment
* XADO is safe
* XADO is guaranteed
Solution:
Metal-Ceramic interfaces are widely known and used in industry. Xado's engineers have developed the technology to apply a metal-ceramic coating to friction surfaces in machines while they run. This revolutionary technology allows moving parts to be repaired and custom fit while in place. The usual 'metal to metal' friction pair is replaced by an incomparably more durable 'cermet to cermet' combination. Xado's patented formulas are available to revitalize virtually any machine.
Fuel economy:
XADO will reduce your vehicle's fuel consumption. Fuel savings of 10% to 15% is very common. Even brand new vehicles have been shown to increase gas mileage by 5%. In industrial applications, a similar savings can be realized in electric usage.
Performance:
XADO will make your cars motor run more smoothly with less friction. It also works to improve engine compression. The result is a smoother, quieter engine with more power.
Extends life:
XADO produces a surface much harder and smoother than steel. It penetrates metal to a depth of 10 to 30 microns, becoming part of the surface it protects. The XADO coating is extremely resistant to corrosion. As XADO works, it "customizes" the tolerances in each unique assembly, resulting in smoother operation. All of this acts to extend the life of machinery by a factor of two to three times. XADO is car maintenance.
Economical repair:
XADO works while the machine works. This means no down time and no new parts. The coating results in actual engine repair. In gearboxes it has been shown to reach a thickness of 63 thousandths of an inch. In piston/cylinder groups, it has reached nearly 8 thousandths. In a high pressure fuel pump, 0.8 thousandths. XADO's greases are formulated to revitalize assemblies worn as much as 80%. No down time, no parts no costly labor. XADO revolutionizes car care! In most cases Xado will eliminate lifter tick noise and reduce piston slap.
The Environment:
XADO works to improve the tolerances in your engine, reducing exhaust emissions dramatically in a remarkably short time. We have documented carbon monoxide being reduced as much as 82%. (See the News piece 'XADO proves it's Environmental Friendliness'.)
Safety:
XADO works where there is excess friction. As the coating is formed and the friction becomes less, the process is stopped. It is self limiting. The coating grows until it has done its job, then it stops. XADO is inert with respect to fuels and lubricants. It does not interact with them or change their properties in any way. XADO works as an engine coating, not as a lubricant.
Guarantee:
XADO guarantees the durability of our coatings for one year, regardless of mileage driven, or hours of usage, when properly applied. In practice, the coating can be effective for a remarkably long time. In a reducer of a locomotive in Ukraine, the coating is still growing after almost 118,000 miles. We guarantee you will be completely satisfied with the results you obtain with XADO Products or we will promptly refund your purchase price.
XADO, the only technology in the world that adds both weight and dimension to worn parts in operation. Xado fully restores their geometry. Chemistry with XADO works. Xado = more power, saves fuel, less wear.
Their claims:
Problem:
What is XADO Gel?
* XADO is safe
Solution:
Fuel economy:
Performance:
Extends life:
Economical repair:
The Environment:
Safety:
Guarantee:
