need to grease up the sway bar bushings and i found this at a local dealer, just wondering if it will work...
I've seen them with and without the stuff. I would just ask the seller of the ES bushings to "throw in" some in the little squeeze tube they have available. You also can get it in a small lidded container and a small plastic jar size. To get sway bar bushings apart you have to take off the metal brackets holding them to the chassis, drop the bar down some, and twist them off (if they're split by design, if not the whole bar must be separated from the chassis and suspension and the bushings slid off of the bar).quote:
Originally posted by jayno20:
im thinking about getting some energy suspension bushings, do they come with said "goop"?
