Originally Posted by StevieC
The conspiracy that the thinner oils don't offer protection like a thicker oil would all in the name of Fuel Economy. That's just complete nonsense.
What ????
The drive for thinner oils is for Fuel Economy, CAFE, or Carbon...name whichever market you are in.
The OEMs tell us that the regulators tell us that, and the oil companies tell us that.
The challlenge, per the OEMs is to provide greater economy with "acceptable" increases in wear (Honda, Ford)
The challenge, per the oil companies is to maintain acceptable wear, in an environment where there is less reliance on hydrodynamic lubrication (used to be defined as the "zero wear" regime, and a higher reliance on boundary/mixed, and additives.
The challenge per API is developing engine wear tests that are representative of the two line above.
I'm happy for you to support your blanket statement above, it's very reminiscent of the rants of aehaas, and CATERHAM, prepared to throw the obvious and readily available information out the window, because it doesn't suit the paradigm that they WANT to believe.
For example you stated that they are keeping the 20s, and changing the engineering (and materials)...that's in direct contravention to your statement above.
WHY do they have to change their materials and engineering, if the oils protect as well as ever ?
WHAT is their motivation for making these changes ?
You can't say that the drive for 20s and 16s is IMPROVED wear can you (although those that came before you certainly did, absolutely without foundation)
