Originally Posted By: JHZR2
This isn't my choice, really. I don't have the time to fix the 328i right now, I'm far too busy with work. And I'm not paying to have it fixed because the car isn't worth enough to me to bother.
I cant imagine snow tires were cheap. Plus wheels and mounting, and the time... wow, Im sure youve spent a thousand dollars.
How much could the repair possibly be? The M5 will be a compromise in the snow, more so than the 328 IMO, even if the electonics get it through. But what bothers me more is the salt/sand/cinder damage to the car.
You could do a lot of repairs for the cost of the snow tires. An 00 328i is in no way worthless. and will be worth a lot more repaired.
They were a hair over 1,000 bucks.
The problem with the 328i is that I don't actually know what the issue is. It could just be it is low on fluid. But there isn't an easy way to check that doesn't involve a hoist.
And if it isn't the fluid, then it probably needs at bare minimum a shift solenoid, at most, a new transmission.
I'm concerned about the elements as well. Which is why I'll have the living Krown Krowned out of it
It'll be fine I'm sure.
The problem here is the combination of the unknown with the 328 and the time required to potentially fix it. If it needs a transmission, I'm not paying a shop to do it. And I'm sure as heck not changing a transmission in my driveway with the ambient temps we have right now.
It was 0C this morning. It is getting cold out, I needed to make a decision as to what was the easiest way for me to ensure my mobility this winter, and I've done that.
If the weather is too bad, my wife won't want to drive in it anyway, so deep snow really shouldn't be an issue. I'd likely have the Expedition if that's the case, because she'd be afraid to drive it.
