Originally Posted By: JeepWJ19
Yes let's wire a high beam switch in the floor away from all the other light controls. It would make too much sense to have the high beam switch on the turn signal lever, and on some vehicles where it also controls regular running lights. We sure don't want that, or having all that on the same wiring harness.
If wiring efficiency is a significant factor, why have 4-way-flasher switches migrated far away from the turn signal switch? They used to be logically located.
Spring-balanced hood hinges were a minor convenience, but not worth their added weight, wasted space, cost, and safety drawbacks. Props aren't so bad, and are far more durable than gas struts.
