10Mbit uses four wires, 100Mbit uses 8, as does gigabit. The difference between CAT5 and CAT5E (gigabit) is the # of twists per foot on the wire.
Hi Overkill,
I stand corrected RE: 10/100B-T uses 4wires (2pairs):
http://en.wikipedia.org/wiki/10BASE-T
1000base-T uses all 4 pairs (8-wires) to complete the bi-directional configuration (making it full-duplex).
Also: if you stuck with legacy wirings with CAT5, don't bother trying gigabit ethernet for sometimes, depending on crosstalks and noise (which is dependent on the run, the environment it operates on, etc.), it may fail to negotiate (between the 2 devices, more prevalent on PC's NIC to switches) up 1 level to 1000b-T, and will either shuts down the NIC, causing the NIC to go up and down (flip/flops between 100B and 1000B) due to negotiation failure.
CAT 5e (350MHz or better) or CAT 6 would be your sure bet when it comes to 1000Base-T, although not always for it still somewhat dependent on the quality of the terminations and more.
Q-TD
