Originally Posted By: Gary Allan
Originally Posted By: BrianWC
I just can't buy the high wear UOAs being the result of cleaning. I think if that were the case every arx UOA we'd see would be through the roof b/c we usually see a lot more cleaning with arx than we do from Redline. That being said, do the wear levels really justify the concern? Redline certainly has the specs to be a fantastic oil. I think the main reason you don't see more about it on here is a.)no overhyped formula changes ie. now with super adaptive, cleansing, sludging-fighting, nano-hypermolecules b.) it's never on sale BOGO or FAR from Autozone/AAP/Kragen/Checkers/Wal-Mart. c.) there's no one on here (publicly at least) affiliated with the company to quiz about the oil.
There's some chelating action with Auto-Rx that's not there with RL ..or at least apparently so..and the components are a bit different..overall. I just think that RL KICKS off some stuff in its aggressive (Ogressif-crock hunter RIP) boundary layer formations. It tends to settle down after a fashion. I wouldn't buy it or use it for that reason. It would be cheaper to use a bottle of Auto-Rx and then use something more economical. I agree with Volvohead. The stuff really has no sensible "economy" to it. It's a performance based purchase ..and a rather narrow one at that.
Oh absolutely. See, back when I was running or had just finished my first arx treat in early 06, I was convinced that it was nothing special and that, based on the chatter on here, I could get the same effect from any high quality ester oil. So, at Tony's urging (which I don't know if he was sincerely curious or just leading me toward a known conclusion) I ran an OCI of Redline to compare the effect to arx. He said he'd already done the same experiment in Helen's Mazda and saw no cleaning. My result was the same. Nothing photographic and the filter wasn't nearly as loaded with deposits as my arx filters had been. I thought maybe I had cleaned everything out but a drop of the pan proved otherwise.
My one arx UOA only showed a 14 Fe and 19 Pb and most of you remember my filter pics.
But don't get me wrong, I have to believe that Redline's results have got to be something cleaning related. I can't fathom otherwise. Same with M1. If I had easy access to Redline locally, it'd be all I would run. But I just can't wrap my head around the logic of it. Too bad I didn't do a UOA on my own Redline run.
