If it is made by Mobil,it will look like a Mobil product.
If it is Warren Performance, it will have either a WPP or a WNE on the bottom of the product.
Latest info for Super Tech High Mileage oils made by WPP/WNE
If you want the info for the regular oil, go to
Oil
and look at their oils, they should be the same or very close to ST.
5w30
Visc. @ 40 C-61.86
Visc. @ 100 C-10.44
Visc. Index-158
Pour Point (F) -49
Cold Cranking Sim. at(C),cP- 6235 -30(C)
High Tempature/High Shear Vis. at 100C,cP-6.96
High Temp/High Shear Vis. at 150C,cp-3.09
NOACK Volatility,% Loss-14.7
Zinc,wt%-.085
Phosphorus,wt%-.077
Calcium,wt%-.250
Sulfur,wt%-.298
Boron,wt%-.018
Shear Stability-8.63
API SN-Approved
Meets API SM,SL
ILSAC GF-5-Approved
Meets ILSAC GF-4
10W-30
Visc. @ 40 C-65.71
Visc. @ 100 C-9.97
Visc. Index-136
Pour Point (F) - -44
Cold Cranking Sim. at(C),cP- 5748- -25(C)
High Tempature/High Shear Vis. at 100C,cP-7.3
High Temp/High Shear Vis. at 150C,cp-3.1
NOACK Volatility,% Loss-11.9
Zinc,wt%-.085
Phosphorus,wt%-.077
Calcium,wt%-.25
Sulfur,wt%-.298
Boron,wt%-.018
API SN-Approved
Meets API SM,SL
ILSAC GF-5-Approved
Meets ILSAC GF-4
10W-40
Visc. @ 40 C-109.7
Visc. @ 100 C-15.53
Visc. Index-150
Pour Point (F) - -38
Cold Cranking Sim. at(C),cP- 6757- -25(C)
High Temp/High Shear Vis. at 150C,cp-3.86
NOACK Volatility,% Loss-13.5
Zinc,wt%-.085
Phosphorus,wt%-.079
Calcium,wt%-.169
Sulfur,wt%-.294
Boron,wt%-.230
Molybdenum,wt%-.0079
API SN-Approved
Meets API SM,SL
