which vehicle/transmission has tranny drain plug?
Camrys and Corollas had them for years, I'm not sure if they still do or not. Beyond that not many manufacturers offered automatic transmission drain plugs from the factory, but some did through their aftermarket performance programs.
What are you anglin' towards ?
Nissan CVTs do, and all Hondas.
I think all Toyota units do as well, but many of the recent 6-spd models are no longer equipped with a dipstick.
To be honest though, I've seen a lot of these "lifetime fill" cars make it past 120k with no issues at all on the original fluid. So for most people, I really do not see a need to change this stuff.
Every vehicle in my sig....including the Packard...but the Mercedes both have over a liter in the pan remaining after draining from the plug, they really need a pan drop at a minimum.
Volvo RWD with Aisin-Warner. Probably the jeep cherokees, toyota cressidas etc that also use this series trans.
Saturn s-series.
Now which ones have torque convertor drain plugs?
Two cars in my .sig do... but probably nothing less than 45 years old does. That was a great feature, you can actually drain those old Torqueflites *completely*. Convertor and pan, nothing left but fluid trapped in small nooks and crannies. The sad irony is they'll run 300k miles with one fluid fill... its the later transmissions that don't have convertor drain plugs that really need the regular fluid changes :-/
i hate dropping the pan on my mercury. that's why i asked. I'll only buy one with drain plug in the transmission.
also ease of oil change is big plus too.
also with transmission drain plug, is it easy to drain the entire transmission/torque converter? don't want any old fluid stay in the system.
Even though fluid changed are required every 30k on those cars, Ford doesn't require a filter change until 150k IIRC. Just change the fluid via the cooler lines and the mess will be minimal.
