Which one - 2011 Outback vs 2012 CRV?
Iowa
Looking at a 2011 outback with 54,000 ($16,950) and a 2012 crv-awd with 63,000 ($15,975)
Which one of these would last to 200,000 miles plus with regular maintenance etc as a daily driver 80 miles highway not interstate in Iowa? Thanks.
Don't know what those two have been smoking, more recent models of honda have had their reliability fall off a [censored] cliff while subaru's has been climbing.
I don't mean to be dismissive of your car buying options, and I am in no way an expert on car buying, but I feel both cars are a bit expensive for their respective model model years, quality cars though.
I think you can start to find 2013-2014 outbacks in that price range once the 2017 models come out, but withe some research and patience you should be able to find a deal close to the price of 2011, a 2-3yr older car.
I am more familiar with Subarus, so do not know much about the Hondas, but I would say check out the 2013-2014 Hondas as well.
-Scott
I'd take the CR-V.
Don't Subarus have a pretty high rate of random engine failures and oil burning? And head gaskets?
No contest, get the Honda CR-V. Better in every way especially long-term reliability. Subaru has a great all-wheel-drive system but that's about it.
Drive the CRV a bunch and see if you can tolerate the wind and road noise.
And most likely the radio is about worthless- but that doesn't bother me.
I didn't like putting 80 miles on my 13 Accord Sport for the above reasons and the harsh booming suspension.
OUTBACK! Anyone else suggesting the CRV does not know both vehicles. My wife went from a Fit to a Subaru and the CRV was her initial first choice. Didn't last long. I drove a friends CRV a fair amount in college.
The Subaru will be:
More comfortable, especially for longer trips.
Safer. It is a tank and one of the few early 2010s car to pass the IIHS small overlap tests. Honda was marginal, Subaru was acceptable (although the dummy received all good metrics)
More reliable - Post 2009, Honda's reliability has been "spotty" at best. 2012 was the resign year for the CRV when Honda corporate was cutting costs. Subaru OB was in its second year of the GenIV OB so I bet it was assembled better.
Easier to fix. Working on a OB is easy... save for those sparkplugs.
The same fuel economy (24/30 Subie vs 23/31 Honda) I can easily get 33mpg in my outback... considering the OB is a bigger vehicle...
Hold its value better.
The Subaru AWD is so far ahead of the Honda. I don't get snow days... it is Subaru. Of the five or so "critical" individuals who come in to work when there is a mess outside, 3 Subarus, 1 Honda, and a VW
I had a '99 OB before I sold it locally. It was 212K+ miles and still ran like a champ. If it was a manual, I might have kept it, but I wanted something more fun to drive and slightly safer.
The Subaru's CVT is actually outstanding and is likely the best on the market for cvt. This is coming from someone who only likes manuals. I love the engineering behind the Subbaru CVT>
I don't have any experience with Subaru but my wife's 2008 Honda CR-V has been very reliable thus far (125k), with only routine maintenance. My mom has a 2012 CR-V that has been equally as reliable but only has less than half the mileage of ours. I do agree with the above statement about road noise especially once the tires get some age/miles on them.
Vote for the Subie.
2011 was the last (or next to last?) year for the 2.5 EJ engine in the Outback. This engine was revamped when the 2010 models came out and Subaru addressed the head gasket problems earlier versions. I haven't heard of head gasket problems in this era vehicles. The previously mentioned oil burning has been an issue with some of the newer FB engines. The rest of the car is built like a tank. You can't buy a safer more dependable vehicle in my opinion. If snow performance even enters the equation it's game set match for the Subaru as its AWD is head and shoulders above the CRV. I've owned both.
They're really not comparable vehicles. The Outback is Subaru's "luxury" vehicle. The CRV is more of a slightly larger, higher off the ground Civic.
I've owned 3 Subarus and 1 Honda over the years and love them, but comparing just these two used vehicles, I'd go with which ever one you're more comfortable in.
Interesting replies, thanks. My current 04' chevy classic has 206,000 miles on it, still runs good but just thinking what a good replacement for it might be.
Originally Posted By: Nick1994
I'd take the CR-V.
Head gasket issues resolved, oil burning is actually lower rate than a lot of vehicles... for some reason a lot of people were really vocal. Never heard of a random engine failure in any recent model year.
I'd take the CR-V.
Subaru's issues were from 96-99 and then 00-04. Headgaskets for the 96-99 was the result of boring out the EJ 2.2 to a 2.5 and it is suspected that 1 in 7 were machined incorrectly (or at least not within a tolerance that would not stress the HF in a high-temp situation). Thus you could have a internal HG failure. It hit Legacy and Impreza models with the Phase I 2.5 engines. The 00-04 (or 98-04 for the Forester) were Phase II EJ 2.5. The machining issues was solved, but the supply for the composite gasket F***ed Subaru over and under-speced their product resulting in external HG failures. What really stunk was that Subaru was using the 2.5 in almost EVERY CAR. Worse, the boxer design gives you two HG to fail so you were really having a high chance issue. So the problem seems a lot more frequent than it was although it is thought that the Phase II engines were not an issue of "if" but an issue of "when". Now note, it was a manufacturing/part issues. Once repaired, there was no worry about re-blowing the HG due to a bad design. Take Honda's transmissions problems that could eat several transmissions in a row. A very different issue compared to the Subaru.
Now, it is important to specify the difference between the internal and external failure. Both cost about the same to fix but are a world apart. Internal failures are bad/worse. This is when you have coolant leaking into the engine. There are a lot fewer signs and can do more damage is not caught early. All subaru folks would watch that temp guage when climbing a hill. Any small jump and a Subaru owner should run into a shop. External failures are when the coolant leaks out of the engine on the driveway. Technically, you can drive the external failure for as long as you like as long as you top it off. The problem is when people just drive on it and warp the heads. Then you are on another level of cost.
Since about 2005, the HG issue is basically silent. You hear about the odd problem, here and there but it is a non-issue. Now, technically the boxer has two HGs so you are twice as likely to have the problem but I have not heard of one single Gen IV (2010-2014) HG issue yet. However, I can point to a few Civic-related HG issues as well. Since yours is a EJ, I would be fine with that vintage engine. Another thing to look at is the EJ UOA. It is probably the best testing engine for being "easy on oil". Some of the UOA reports for 7.5K+ look like 1000 interval.
As for the oil burining... the FB engines might have a few. I know they did a TSB/Recall for a few for improperly seated rings but it is not as vast of folks would like to think. One of my co-Workers has a "burner" but it is a 1qt every 1500 miles. The thing that I think it is using oil from is that my co-worker commutes 70 miles up a mountain every day. You can't drive up 2000 feet at highway speeds every day and not use oil. We are watching it and it had it checked by Subie. While I think that there were some vehicles with issues, I think the real issue is going to a 0w20, longer OCI, and a LOW OIL LEVEL LIGHT. I am certain that 95% of those claiming the issue have never checked their oil in between oil changes. The addition of that light is finally telling them that something is using oil. Mine will be about a qt low at 6,000 and I do a fair amount of mountain climbing. That is about normal for most cars except my old EJ motor.
Likely the same. I will state 150k+ the chance of a non maintenance item cropping up goes way up irrelevant to car maker.
80 miles per day is a lot. Buy the one you prefer.
If you really need or use Awd Subaru is superior. Honda is more a Fwd+ system based on my observations of friends visiting our terrible driveway at our ski home.
