Which lacquer thinner to put in gas tank?
This is the one I put in my tank, get it at Lowes. ;)
what does it for you?
I see in SDS is has methanol and acetic acid,....
67-56-1 Methanol {Methyl alcohol; Carbinol; Woodalcohol}25.0 -35.0 %
67-64-1 Acetone {2-Propanone} 20.0 -30.0 %
NA Petroleum Hydrocarbon Mixture (Alkanes andCycloalkanes)20.0 -30.0 %
141-78-6 Acetic acid, ethyl ester {Ethyl acetate} 108-88-3 Toluene {Benzene, Methyl-; Toluol} < 5.0 %
111-76-2 Ethanol, 2-Butoxy- {Ethylene glycol n-butyl ether,(a glycol ether)}< 5.0 %
https://www2.pcad.edu/Facilities/he... Shop/WM Barr/klean strip lacquer thinner.pdf
