Originally Posted by willbur
Greetings-
I think the air filter is more important than the oil filter. Makes the job of the oil filter easier by preventing wear producing material from getting into the engine in the first place.
There's still oil contamination from combustion blow-by past the rings. The air filter does nothing to help reduce that source of oil contamination.
And your point is...?
Correct me if I'm wrong, but that combustion blow by is not the hard abrasive material that scours bearings, cylinder walls, etc. The oil filter catches abrasive contaminants that gets by the air filter and normal engine wear material. I think most of the material that's found in the oil filter makes in in past the air filter. So...IMO oil is more important.
My point is oil gets contaminated from other sources besides the intake air. Of course an air filter is important, but so is an oil filter to catch what might get by the air filter and/or from the other sources of contamination (combustion blow-by, engine wear, etc).
Cleaner oil is better than not (every machinery wear study proves that), and the oil filter is the only thing that actually removes contamination that makes it into the oil, regardless of what that contamination is or where it came from. My viewpoint is if a better filter keeps the oil cleaner, then I'm all for it. I highly doubt I'm going to miss spending $3 more a year on a better oil filter.
The oil is the "life blood" of the engine, so asking if it's more important is basically obtuse. I'm not saying an oil filter is more important than the oil, I already said that earlier in this thread. My point is the oil filter is also important, and for me that means using filters (air and oil) that give me the best filtering efficiency possible.
