If it has caps you can pry off , keep the battery watered . Check when you change oil .
Check for corrosion at the same time and clean as needed .
Check tension on the belt . If it does not have a spring tension-er . Check the condition of the belt & pulleys .
Check the alternator charge voltage .
There are YouTube videos showing the acid being dumped out & the flushed with clean water .
Then add the " correct " solution of alum ( I think ) or Epsom salt .
Best of luck to you all ,
