when did rotella switch to CK-4?
Originally Posted By: HouseTiger
So is the bottom line that Rotella T-6 is no longer suitable for use in gasoline engines ??
Hi @HouseTiger! As @Garak mentioned, in mid-2016 we introduced a new product to our family of oils, Shell ROTELLA T6 Multi-Vehicle 5w-30, which has the SN approval for gasoline engines. - The Shell ROTELLA Team
Thanks much. Now to see how long it takes for it to appear on Walmart shelves.
Previously, heavy duty engine oil marketers could claim an API gasoline performance standard on their products if they met CJ-4 and the required performance tests for gasoline standards. Additionally, a waiver was granted for claims of API gasoline performance in cases where products did not meet the chemical restrictions for gasoline specifications (specifically phosphorous limits required for SN).
The recommended viscosity grades for modern gasoline engines are XW-20s and XW-30s. As such, this waiver process is being phased out. Heavy duty engine oils which are XW-30s (and which claim API CK-4 approval) cannot also claim API gasoline standards unless they meet the current phosphorous requirements/limits. The new fully synthetic Shell ROTELLA® T6 Multi-Vehicle 5W-30 is one such product that meets the performance requirements of API CK-4 as well as API SN and is formulated with 800 parts per million of phosphorous, which meets the API SN requirements.
While the industry waiver is still currently in existence for heavy duty engine oils that are XW-40’s, this remains in discussion to be addressed by the API in the near future. However, the Shell ROTELLA® brand has made the decision to remove API SN claims, regardless of viscosity, from our other products which do not meet the preferred low-phosphorous chemistry for gasoline engines. It is important to note that there is no change in formulation associated with this change. It simply means that Shell ROTELLA® products will no longer claim formal API SN approval for products other than our fully synthetic Shell ROTELLA® T6 Multi-Vehicle 5W-30 on labels, technical data sheets, rotella.com and marketing materials moving forward.
- The Shell Rotella Team
It is very nice to have industry reps that honestly [as possible] answer questions.
I don't believe Shell or anyone else would label containers first, then blend to suit.
"Oh dear! We forgot to change the ink labeler on a thousand 5 gallon pails and we have a box of 5,000 glue on labels that also say CJ-4/SN, what should we do?"
We are talking maybe a few hours of production to run out the old labeling with the old CJ-4 blend, if that actually happened, which I doubt.
Shell answered that question a couple times here already over the years. Every time there's a new API spec rollout or a dexos1 change or the introduction of dexos1 in the first place, we go through the same song and dance.
For those interested in Shell Rotella T6 Multi-Vehicle 5w-30, I would encourage you to contact your local distributor. The pricing I was quoted (from a not-quite-local distributor) was pretty amazing.
