I'm getting a set of lightweight wheels with an offset of +50mm
i would've preferred a lower offset (around +35 to +45mm)
my OEM steel wheel offset was +45 btw.
the car is a 2007 Corolla CE that came stock with a 15X6 steel wheel.
NOW, the Traklite's i'm getting (which are 16" and weight 12 lbs.) have an offset of +50mm.
I suspect these will fit. although the fitting will be an "innie"
someone suggested wheel spacers.
unless wheel spacers are PERFECTLY smooth, i suspect that they may not be a good idea.
any thoughts about this?
