Originally Posted By: Kruse
I've torn down quite a few engines with stuck rings and it is my opinion that usually stuck rings will remain stuck until the engine is tore down and the piston is removed and cleaned up. If the rust and crud is somehow magically removed, it may score the cylinder wall and use just as much oil as before.There are exceptions, of course, if the ring isn't stuck too bad. But quite often there is no real way to get the crud out from behind the second or third ring without a teardown. Despite what you read on the label, the deposits just don't magically evaporate into thin air. (or thin oil)
I just watched an episode the other night I think it was Texas Car Kings or something? Any way, they bought an old car at auction, the motor was stuck/seized and they broke it loose. Seemed to run pretty good afterward. Of course you cant go by TV shows.
