I decided to do an oil change in my fiance's 2000 Mitsubishi Mirage. She has put almost 3K miles on it and it's been 3 months, since the last oil change which was done by Wal mart. When I pulled off the oil cap, on the bottom of the cap I saw a milky substance which looks like milkshake. It's a cream/tan color. My first thought was coolant got into the oil due to a bad head gasket. The car has 61,000 miles on it. The oil has been change every 3,000 miles since she got it with 30,000 miles. I went ahead and drain the oil. the oil that come out seems to be normal, dark brown/black color. After I pulled off the cap I looked into the oil fill hole and saw little bit of the same substance on the cams. Any idea what this could be? The car is not loosing any coolant, so the head gasket might be out of the question. The last oil used was Pennzoil 5w30 and a Super Tech filter. Later on I'll see if I can post a pic to give you guys a better idea.
