Originally posted by mtgrs737:
Back in the bad old days they used to use 30w non-detergent oil as two cycle oil at the then common 16 to 1 ratio (8 oz. to the gallon). That oil was tough to get mixed, smoked like crazy, stunk something awful, fouled plugs, and carboned up ports and combustion chambers but it was all they had and it worked for them. Today's oils are petrolum engineering marvels by comparison, however we still need to ensure that there is enough oil going through the engine to provide a constant film on all the needy parts under all loads and temps. At 32 to 1 ratio I am not experiancing any of the negative effects that the folks from the bad old days did, thus I have a hard time understanding why some folks want to put as little oil in their mix as possible. Bonnie John, the answer is yes and no, yes, you will effectively lean your air/fuel mixture slightly but no it is not usually a problem even in fixed jet carbs (mostly because fixed jet carbs are one big compromise anyway). Bullet, you get away with the tcw3 stuff because it is still oil, even though the additive package is not the best for the application, you would be better off using an air cooled engine oil for the air cooled units. But hey, you own the equipment you are abusing, and until they pass some new law prohibiting it you can use the wrong but cheap oil if you want. IMHO
