What Oil Filter, and Brand oil are you guys using?
'00 Toyota 4Runner - PureOne + Mobil-1 5w30.
'87 Nissan Pathfinder - Motorcraft + Mobil-1 10w30.
'90 Mustang 5.0L - Motorcraft + Mobil-1 5w30.
The Toyota and Nissan have remote adapters to use the same FL1A size filter as the Mustang...
[ February 05, 2003, 03:27 PM: Message edited by: jsharp ]
2003 Ford 4.2 V6
5w30
K&N
[ February 05, 2003, 11:28 PM: Message edited by: YZF150 ]
99 Chrysler 300M - SuperTech ST8A and Mobil 1
97 Olds Silhouette - SuperTech ST3980 and Mobil 1
2001 Chrysler PT Cruiser 2.4L I4
Mobil1 10w30
Penske PN2825
2000 Toyota Tundra 4.7L V8
Mobil1 10w30
Penske PN2825
1981 Corvette 350CID V8
Castrol GTX 20W-50
Castrol MaxPro CM30
1995 Harley FLHT & 1999 Harley XL1200S
Mobil1 15W-50
H-D OEM
Fortunately the PT and Tundra use the same size filter with identical specs, so I was able to loot the local K-mart of their entire supply of Penske 2825's last October when they were clearing 'em out (29 @ $1.15ea). Should take care of my filtration needs for the next decade or so.
'93 ZX-11 Kawasaki (18K): Emgo/Fram/Kaw filter with Amsoil 100% Synthetic 10W-40
'92 SVX (99K), '91 420SEL (130K), '87 F250 460 Carburated(!) (177K) & '84 Lincoln Town Car 302 (64K)...
After reading this Board I'm seriously thinking about exclusively using OEM filters & Penzoil LongLife 15w40 in all of these, except the ZX-11 (Just as soon as I've used up what's left of the case of Havoline Formula 3 10w30 Semi-Synthetic I got for $0.57 per quart!). And the 1-filter each Purolators I have sitting on my shelf...
Great oil!
It's darn cheap, should certainly lubricate well, has a great cleaning/additive package & should protect these engines very well.
2002 Ford F150 w/4.6L V-8
Motorcraft 5W-20
Motorcraft FL820S filter
1996 Ford Contour w/2.0L L-4
Mobil 1 5w30
Motorcraft FL200 filter
I know I'm a social pariah for using the Ford 5W-20, but while it's under warranty and it's doing no harm(seeUOA)I'll stick with it. The Contour engine is most happy in the upper RPM ranges so I use Mobil 1 for extra protection. Also to make up for my "mistreatment" of the car by using Castrol Syntec 5W-50 with a Fram filter
for the first 30,000 mi of it's life. Please forgive me, I didn't know right from wrong until "you" showed me the light!
Whimsey
Chevron Supreme in my high miliage Miata and Probe GT, Mobil 1 in the newer Miata.
Either OEM (WIX) or Pure One filters.
Rich
[ February 09, 2003, 12:33 AM: Message edited by: RichSD ]
1993 Taurus SHO 3.0L
5w30 Mobil Drive Clean winter, 10w30 otherwise
K&N HP-3001 oversized
120 mile daily driver
1997 Taurus SHO 3.4L
5w30 Amsoil synthetic
racing and fun
The SHOs have high volume, low pressure oil systems and a high flow is important.
1999 Jeep Cherokee 4.0- ST 10w30 and ST oil filter
2002 Dodge 1500 Ram Q/Cab 4.7- Quaker State or Mobil dino 10w30,
Fram oil filter
1970 Plymouth Road Runner 383- Quaker State or Mobil 30 wt and Fram or Mopar "restoration" filter.
1971 Dodge Demon 440,drag race car-Quaker State or Mobil dino 10w40 and Fram oil filter.I use only Fram on this car because Fram pays contengency money if I win.
The new Dodge will probably switch to ST 10w30 also,along with ST filters.
All change intervals are at 3m/3000 miles,except the Demon,it gets changed every 3 race events,and all are performed by me.
[ February 16, 2003, 10:39 PM: Message edited by: Chris 2421 ]
Wife's 5.0 Explorer I use Mobil 1 5w30 and Motorcraft filter.
My 5.4 F-150 currently Motorcraft 5w30 either a Motorcraft filter or a Supertech.
The 5.4 has the filter mounted vertically so the antidrainback valve does not seem quite as important. Please correct me if I am wrong.
'97 Maxima MFA 5w30 w/ ST filter
'99 Expedition TropArtic 5w30 w/ ST filter
Expy in middle of Auto-rx treatment!! Thanks Frank
I will use Amsoil 10w30 and an AC Delco UPF 44 Gold oil filter for my 2003 vette. I use Valvoline and Pennzoil with my Izuzu pu and my wifes Taurus. Motorcraft oil filter for the Taurus and a Wick or Fram with the PU.
'98 Pontiac Transsport
3.4l V6 K&N (oversize)-
M1 5-30 in the cold // 10-30 in the summer
between 5000-6000 km regardless of time.
2002 Acura 3.2l V6 vtec.
5-30 Royal Purple with K&N filter.
6000km +/- or 1 year
2001 Olds Intrigue w/ 3.5L DOHC V6
AC PF2129 oil filter
2000 Acura 3.2TL w/ 3.2L SOHC VTEC V6
Mobil 1 M1-104 oil filter
All my internal combustion engines use Amsoil Series 2000 0W-30.
1991 Toyota Camry
Mobil Drive Clean 5w30 (10W-30 warm months)
Toyota OEM filter (made in USA)
1991 Toyota Pickup
Same as above
1999 Toyota Camry
Mobil 1 10w30
Toyota OEM Filter (made in Japan)
