Acccording to Toyota's recommendation for 2003 Echo, the transmission fluid should be replaced after 60k miles of service. With a Frantz transmission filter and regular TP changes and addition of fresh fluid,
1. how long can I keep the fluid before changing it? Or does it ever needs changing?
2. what will be the TP change interval?
The Echo is equipped with a standard factory transmission cooler that resides at the bottom of radiator.
