Originally Posted By: 2012AccentSE
This may be perfect for the Corolla then. It still has the OEM fluid in it (WS) and is at 126k. I want to change it out soon since it is pretty dark. No issues other than color of fluid. Ie. hard shifts, slipping, etc.
Lubegard is your call, but do change your fluid a couple of times. I bought a used 2010 Vibe from Carmax in 2010 with about 29k miles. I changed the ATF and was surprised by what came out. The fluid was really dark and also had a gray sheen, but didn't smell bad. I sampled another pan drain soon after, and it came back with high aluminum. I did one more drain and fill, then dropped the pan and changed the filter, and started draining the pan at every oil change (just over 2.5 quarts). Aluminum is trending down and the trans has given me no trouble.
If your Corolla has the 4-speed, the drain plug takes a 10mm Allen socket. NAPA has a good replacement plug gasket, #ATM PB2403. This is thick like the stock one--my NAPA also had one that was a lot thinner. I got several changes out of my factory gasket, but it's good to have a new one on hand. A drain & fill takes 2.7 quarts, and the filter change took about 3 quarts.
I have used about two bottles of LG at the recommended 1oz. per quart over the last 50,000 miles, and can't say I noticed any effects good or bad. The trans does nothing unusual and shifts like it always has. I switched from WS to Maxlife for the last two changes or so.
