I have a 2000 Ford Ranger. I have always used 5w30 in the engine excpept this time I used 5w20. I am very worried that the 5w20 is hurting the engine seeing that it calls for 5w30. I don't want any wear on the engine then it gets already for daily use normal use.
My question is which oil is better in my case of living where I do, in Georgia? 10w30 or 5w30. I know 5w30 is what it calls for. But, if 10w30 would be better for the v6 that is in it and for the climate that it is in I will switch. If everyone tells me to use 10w30 my next question is over periods of time with start up wear won't the 10w30 cause more wear on the engine prematurly? 10w30 is a thicker oil correct compared to 5w30? So when cold I am essentially causing more engine damage using 10w30?
Help
Help
