What exactly do the VW specs mean?
Pacnw
On some forums, I have heard a lot of people talking about how if an oil meets VW 502 specs that it is "the best" in terms of protection vs. any oil that doesn't meet that spec.
Also, they talk a lot about the "hierarchy" and that a 503 oil is better because the number is higher and therefore a newer and better spec.
I believe both statements that are so often thrown out as fact are wrong, but I don't really know what exact factors the VW spec. considers. Does any body have a link to the actual test? I assume the following factors are part of the VW spec.? Does anyone know how much anti-wear/protection weighs vs the other factors?
1) mpg
2) emissions
3) starting viscosity (start of test I mean)
4) ending viscosity (end of test I mean)
5) anti wear/protection
6) detergency
7) other?
It just doesn't seem right to talk about VW spec oils as the holy grail for protection when instead I think the specs are trying to balance many factors, one of which is anti-wear/protection.
The only thing the VW 502.00 spec means is that the oil's been tested in the 2.0L, 115 Hp VW gas engine. There are specific limits for valvetrain wear, oil deposits, oil consumption, viscosity increase and TBN retention. As I recall the test runs for approx 200 hrs and no makeup oil is allowed.
VW 505.00 is similar bit uses the old 1.6L. IDI, VW diesel engine.
VW 500.00 (officially invalid) Oil for naturally aspirated gasoline and diesel engines with normal fill without extended interval (15000 km – 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests
VW 501.01 (officially invalid) Oil for naturally aspirated gasoline and diesel engines without extended oil change interval (15000 km – 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA A2 + additional VW tests
VW 502.00 Oil for high performance gasoline engines without extended oil fill change interval (15000 km – 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests
VW 503.00 Oil for gasoline engines with extended oil fill change interval (30000 km – 2 years), HTHS viscosity 2.9 - 3.4 mPa-s, ACEA A3 + additional VW tests
VW 503.01 Oil for AUDI turbo-gasoline engines with extended oil fill change interval and Volkswagen W8 and W12 engines (30000 km – 2 years), HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests
VW 504.00 For Euro IV gasoline engines with extended oil fill change interval (30000 km – 2 years) HTHS viscosity min. 3.5 mPa-s, ACEA A3 + additional VW tests, 5w30 only, mid-SAPS
VW 505.00 Oil for diesel engines without extended oil fill change interval (15000 km – 1 year), HTHS viscosity min. 3.5 mPa-s, ACEA B3 + additional VW tests
VW 507.00 For Euro IV diesel engines with extended oil fill change interval (30000 km – 2 years) HTHS viscosity min. 3.5 mPa-s, ACEA B4-04 + additional VW tests, 5w30 only, mid-SAPS
Hi,
jpr - VW's Test protocols are outcome specific and the relevant ACEA Quality standard is typically the starting point. That is one reason why ACEA was formed
Some of VW's Test protocols may also involve VW's component suppliers for such things as cam chains and gears, camshaft treatments, actuators (especially valve train), pistons, ring packs and even the supplier of turbochargers, superchargers and perhaps the block/heads and the like. These people may work with VW to devise the Test protocols and seek outcomes to substantiate Warranty provisions and the like
Much of the testing will be done using very sophistocated wear measurement practices such as. For the 506.01 protocol a 1000hr radionucleide test was devised and waer measurement taken hourly in nanometres - one millionth of a mm!
It is unwise IMHO to discount the engine makers tests. They will be the most comprehensive needed before the end user's real world - in day to day use operation
VW's lubricant supplier (currently Castrol) works on field testing outcomes and typically have large fleets of vehicles substantiating the Lab. results in real world operations
Many of these vehicles are placed in used where specific use occurs with normal drivers - high speed motorway, in town and at the extremes of temperature and etc
I was too lazy to upload it before, but here's some slightly dated info from Motul on the VW test requirements -
I totally agree with you on the value of engine maker's testing.
Seems like the point with European specs is not how to maintain your engine for the least amount of money but how to save the natural resources, at any cost. I mean do you think there is any point in keeping the oil for 20000 miles inside the engine apart of conservation? Oil is cheap here is USA, so change more often...
Or maybe more accurately, how to achieve maximum marketing success by showing how green-friendly your cars are. Or some cars like Porsche use the 20,000 mile OCI as a marketing tool to show how infrequently the cars need to be serviced.
quick correctionss:
503.00 & 503.01 = variable service intervals (up to 30,000 km)
504 & 507 are suitable for both variable and fixed service intervals.
of course, there are 505.01, 506.00 and 506.01 for diesels also.
505.00 is not for ALL diesels. The PD Motor (2004-2006)requires 505.01 or better. So 507 would be fine, their oils are backwards compatible.
saaber1,
You can find lots of info related to VW testing. Here is one test lab on the T4 sequence: http://www.swri.org/4org/d08/global/volkswgn/default.htm
"Better" or "best" is relative. First you need to evaluate what the OEM testing means, then determine if it is relevant to yr app and how much so, and then evaluate other items like price/availability/OCI.
Generally I find meeting OEM spec's is "better to have" then not have. But having an OEM spec does not mean it's "better", for instance...testing cost money...if the market for the oil is perceived to be small ...why test ?
"Oil is cheap here is USA, so change more often... "
Or oil needs to be changed more often in the US because it's cheap.....
They mean we can't use any of our existing oil every time we get a new VW.
We've got a new Sportwagen TDI coming in next month (got the VIN), which is a 507.00 engine. So despite having 100+ quarts of top shelf oils on hand (including GC, RL, RTS and Schaeffers), it's back to the VW dealer to buy a case of "507".
In your case, you really ought to choose your new car based on the oil you have in stock.
Well, the porsche intervals are not odd here in europe, its more like standard to require 20-30kkm or two years OCI for normal conditions. Often drivetrain warranties are valid for 100-120kkm.
I would like to know the average car life in years and km for US and Euro vehicles.
In spite of the longer intervals, I seldom hear about shot engines here. How long do you drive a car?
I don't mind buying yet another oil type. A small inconvenience for the new clean diesel benefits (including a tax credit).
It all gets used around here, one way or the other.
Still, I do sometimes miss the days when one oil would work satisfactorily in just about everything we had.
Don't forget, scheduled maintenance for the first 36k miles is free at the dealer.
Gotta love that $1,300 tax credit!! :)
Tim
I regret ever taking my new Audi to the dealer for "free (or any) service." I will never make that mistake again in the US.
Tim
I'd rather they kept the earlier 4/50 warranty on the '09s and let me eat the maintenance. I'll do my own changes at 5k anyway, so I'm sure it's getting the right oil at least half of the time. VW dealer service can be spotty.
The tax credit is a nice break, as many dealers are selling the one or two JSW TDIs they get at MSRP+. A bad model roll out.
Tim
Most folks have been able to find the 2009 Jetta TDIs and Jetta TDI Sportwagons for list price.
There are always some dealerships that try to add on a "marketing adjustment" to any model that they perceive to be in short supply. This is short-sighted, even if they manage to sell a few cars at MSRP plus $2000 or even more -- think about all the prospective customers who wander onto the dealer's lot, see those extra charges, and resolve to never set foot on a VW lot again.
I remember seeing an R32 sitting on a lot, six months after they were sold out at all the other dealerships. The brake disks were rusty, the car just looked bad.
Auto dealers have a really horrible reputation anyway, this sort of behavior is really repulsive.
Wandering back to topic, I would let them keep their free oil changes during the warranty period.
Going fully back on topic, I would use the VW507.00 oil during the warranty period. After that there might be some experience with the API CJ-4 oils -- I suspect they will do the job.
