Originally Posted by code5coupe
Originally Posted by MolaKule
The OP's question has been answered in multiple ways and the OP should re-read the background information on Friction.
What background information are you referring to?
Something in this thread?
Yes, obviously Posts 5151172, 5153004, 5153027, 5153191, and 5157818 are being referred to and I suggest you review and
study them.
Here is another 'basic' explanation: The FM chemical compound modifies (changes) the Coefficient of Friction (COF) between the respective surfaces "on-the-fly" depending on the
relative speeds of the
rotating components and the
applied pressure forces. That is, it decreases
OR increases friction depending on the
applied pressure forces in order to prevent Stick-Slip which causes shudder.
Sounds like some truly magical stuff if it can perform two opposing functions. Do you know what chemicals/elements are in this elixir?
There are no
opposing functions involved here, which continues to show your misunderstanding of the subject. For the third time, the FM chemistry modifies the COF
on the fly according to relative speeds and applied pressures.
Do I know what chemistry is used in LS additives? Of course.
What does it do when there is no clutch involved, as in an open diff? Does it increase or decrease friction or does it do nothing at all in an open diff? What about when it's used in a helical gear-type limited slip, does it know when to slip and when to not slip in that situation?
Had you studied Posts 5151172, 5153004, 5153027, 5153191 and 5157818 you will see I have never stated this LS additive applies to Torque sensing Torsen-type differentials.
That is a different topic entirely.
Had you googled this
The Torsen differential* is a purely mechanical device; it has no electronics, clutches or viscous fluids. The Torsen (from Torque Sensing) works as an open differential when the amount of torque going to each wheel is equal. ... The design of the gears in the differential determines the torque bias ratio.
https://auto.howstuffworks.com/differential6.htm
you could have answered your own question.
