What are NEMA 6-20 250V receptacles used for?
I recently moved into a home that has several of these outlets in various places throughout. After a bit of googling, they appear to be NEMA 6-20 250 volt receptacles. In my 52 years, I haven't ever owned anything that plugs into this type of receptacle. Do you all have any of these outlets in your place, and what do you plug into them?
I plug my Nissan leaf charger into one.
People seem to use it for 240V air conditioners (not the kind you put in the window, but apparently there are special air conditioners that use their own 240V circuit)
Some people also use them for EV charging
That's what people said in Amazon reviews of a NEMA 6-20
Further reading says it's used in commercial kitchens :unsure:
That makes sense if you are limited on amperage, but can put a 2 pole 20A in at 240V nominal. You'll get double the wattage of a 120V 20A.
If you have several of those outlets that won’t ever be used (besides the 240V window AC) they can very easily be swapped out for regular 120V outlets and be of more use to you.
There is no shortage of outlets in this house, so thankfully no need.
