- Joined
- Jul 19, 2021
- Messages
- 451
Louver lovers and haters what do you think about the louvers on this Champ XL? All the louvers near the top are pressed closed. I'm interested in any feedback you have.
What I'm asking is do you think these louver cutouts are adequate?This has been discussed before, if you are not happy with it, then find an oil filter that has holes instead of Louvers!
would think that top row got smashed as the roller joined the center and top sectionsIf it's just the top row (which seems to be the case) and the others look open like the louvers below that top row (like in red circle), then I'd say nothing to worry about. The machine just didn't do the row at the end as well.
Kawasaki mower engines take the Ford thread filters 3614. The 7317 won't fit.Thanks everyone. I made pawn this one off to my Kawasaki mower. It's a 7317 (Honda) size. I really like everything about the filter except these louvers. That's what happens when you buy a filter online sight unseen.
Yes, the louvers also face the other direction, but if the ones facing the filter base are closed up, you can bet the ones facing the other way are the same.There are just as many openings facing the opposite direction when you look down these louvered tubes, you're only seeing half of them. I had a Mazda value line filter I would have sworn none of the louvers were open. I cut the filter open, pulled the tube out, sealed one end, and was able to breathe through it no problem like it wasnt even there. I gave up worrying about louvers at that point. Add up the area of the louvered openings and compare it to the feed and drain holes in the filter base on the engine and I'd bet the filter has way more flow capacity than those holes.
Man I appreciate it. I don't know what I was thinking. I have the Supertech version of the FL910s filter on there right now.Kawasaki mower engines take the Ford thread filters 3614. The 7317 won't fit.
My 2¢
Purely subjective based an a visual inspection, but anything close to resembling this is a "no-go" for me.When would you say louvers are not big enough?
