B Blaze Joined Dec 31, 2010 Messages 1,545 Location Washington State (East) Jun 5, 2016 #21 Also wet the ground where and before you pour. This helps prevent the concrete from getting moisture pulled out from a dry ground or base. We always wetted the conctrete the first day the sealed the next with two coats of concrete sealer.
A Andrew1972 Joined Jul 11, 2015 Messages 7,723 Location New England Jun 5, 2016 #22 The correct answer is depends on mix used and additives in it. Your dad advice was likely sound with junky mix.
