Originally Posted By: Fazzone
RoGue, I had a similar issue with my truck this summer, the make or break part of replacing it will be whether or not you can get the fan/clutch assembly off the old pump. I spent a lot of time to get mine off and finally took the pump and fan off together so I could put a vise-grip on the pulley to hold it in place. New pump comes with the pulley so no need to worry about damaging it. Also, make sure you have some rtv silicone around to help hold the gaskets on during assembly. It's a pretty straightforward job, just take your time and you should be fine. Now might also be a good time to replace the belts too while you're at it.
Thank you... I said this early on and was ignored. I think most seemed to have forgotten that the fan/clutch thread on to the water pump.
