Watched a documentary on OceanGate
The Willow Creek District AVA
Sue and I watched a documentary about the Titan last night, the deep sea vessel that imploded. The implosion took just two milliseconds (0.002 seconds). Human cognitive awareness takes 25 milliseconds. One of the experts said something truly bizarre. "It's not like they were living and then died. They were living and just an instant later they ceased to EXIST". :oops:
Scott
Very sad story for both them and their families.
That guy did most of the talking about how safe/revolutionary it was but people should have listened to the experts who expressed serious safety concerns ( why you have to be careful who you listen to ).
Unfortunately it seems as if they all knew something was very wrong before it imploded even though they went instantaneously.
The epitome of arrogance ( owner ).
Yet another instance where they should have used metal, instead of a cheaper plastic (or plastic like) material.
Composites, including the carbon fiber used on the Titan's hull, are great under tension but not so much for compression. Basically the opposite of concrete. That's why airliner fuselages are leaning towards composites but "real" submarines still use good ol' steel.
That's what happens when management ignores the engineers (Boeing, are you listening?)
Scott
Some of that may be based on your belief system
Scott
I assume it was on a streaming service? Which one, and what was the title?
I just watched it.
I certainly won't be the first to claim I knew nothing of this showboat's operation. That's exactly what this Rush guy was. PT Barnum. If he spoke directly to me, I would not believe much of what he said. I actually thought - foolishly - the whole operation had some semblance of rigor when it was operating................see there is the problem, and should be regulated, and I am not a regulation person.
I got heavily rabbit holed after it happened, and there were just so many "NO"s yelling in my head at every new piece on information.
Day one as soon as they mentioned carbon fibre construction, with titanium vessel ends, told my wife that it collapsed like a dented coke can....then a few weeks ago they mentioned a "bang" and permanent deformation of the strain guages...and they went down again after....for a bloke who was so confident of his design and understanding, to have not scrapped the hull was criminally negligent.
Design out of approved standards - engineers CAN do that where not possible/appropriate
Carbon fibre in compression - I'll pass
Carbon fibre laid axially and circumferentially - when they were specificaly told diagonally - I'll pass (and it wouldn't have changed mind on the last point).
Thick walled vessel of laminated construction...I'd do it for a pressure vessel, not for this.
Glued on end caps - I'll pass, I know that's the only way, but see point two.
Not only was the cylinder surrounded by a pressure, but it's also a column in buckling keeping the end caps apart...do the trick where you stand on a coke can and get someone to poke the side.
Just no....even without the PT Barnum aspect.
Scott
A recent video on YouTube came out where the ctew was tracking the vessel then there was a bang then silence. One of the engineers I think instantly knew what happened. A few early investors looked at it and ran. A coupon of engineers told the ceo that you can't epoxy carbon fiber to titanium which from memory gotbthem fired.
Did you know any details on the construction say a year before the implosion?
