Sam_Julier
$50 Site Donor 2024
Just received UOA from Blackstone after switching to Redline 5W-30. 47,710 miles total, 6,320 OCI, all highway miles. No oil consumption. TBN was .8 which is quite low for this oil. Spoke to Dave at Redline who felt the number is an error. Blackstone re-tested and came up with .7. This is the first Redline oil change on the car, all previous were bulk oil at dealership, 7,500 OCI. Oil analysis was exceptional with no metals - just a low TBN. Not sure what to make of this and would appreciate any thoughts.
HENRY: No problems to report in this sample from your Volvo. Wear metals were quite low compared to averages, which show typical wear levels for this type of engine after about 5,700 miles on the oil. Titanium is probably residual additive from one of the oils you ran in the past. The viscosity was in the 5W/30 range, just like it should be. No harmful contaminants were found. The TBN was 0.8, which is too low to recommend going much longer on the oil. Anything less that 1.0 shows that the oil is almost out of active additive. Stay between 6K and 7K next oil. Nice!
MI/HR on Oil 6,320
MI/HR on Unit
Sample Date
Make Up Oil Added
47,710 UNIT / 06/13/12 LOCATION
0 qts
UNIVERSAL AVERAGES
AVERAGES
ALUMINUM 22 3
CHROMIUM 00 0
IRON66 12
COPPER 2 2 4
LEAD00 3
TIN00 1
MOLYBDENUM 554 554 77
NICKEL 00 0
MANGANESE 0 0 1
SILVER 00 0
TITANIUM
POTASSIUM
BORON
12 12 0 2 2 1
62 62 43
SILICON 77 6
SODIUM 33 33 25
CALCIUM 2779 2779 2189
MAGNESIUM 9 9 98
PHOSPHORUS 1210 1210 711
ZINC 1264 1264 834
BARIUM 00 0
Values Should Be*
SUS Viscosity @ 210°F 58.4 56-63
cSt Viscosity @ 100°C
Flashpoint in °F
Fuel %
Antifreeze %
Water %
Insolubles %
TBN
TAN
MI/HR on Oil 6,320
MI/HR on Unit
Sample Date
Make Up Oil Added
0 qts
UNIVERSAL AVERAGES
AVERAGES
ALUMINUM 22 3
CHROMIUM 00 0
IRON66 12
COPPER 2 2 4
LEAD00 3
TIN00 1
NICKEL 00 0
MANGANESE 0 0 1
SILVER 00 0
TITANIUM
POTASSIUM
BORON
12 12 0 2 2 1
62 62 43
SILICON 77 6
SODIUM 33 33 25
MAGNESIUM 9 9 98
ZINC 1264 1264 834
BARIUM 00 0
Values Should Be*
Flashpoint in °F
Fuel %
Antifreeze %
Water %
Insolubles %
TBN
TAN
