Originally Posted By: Jetronic
with 300% more power at the same rpm, the lifespan is better measured in minutes than hours or miles. Unless you change all of the internals.
Not necessarily. The Toyota 2JZ, Nissan RB26DETT, and BMW N54 can get that kind of power increase (or near it) and handle it reliably.
A BMW N54 with 1400 bhp and over 1300 lb.ft? All at the same rpm? Somehow I doubt that is reliable...
The N54 pushes around 290 lb. ft. stock to the wheels. 3 times that would be 870, not 1300.
Currently they seem perfectly reliable at around 650 ft. lb, and people have ran them at around 800 for a year+ before any issues appear. Usually it is the pistons that will go, not bearings. Of course you will have less reliability with more power, but they don't fail in minutes.
One thing I forgot to mention though that is all the examples I gave will reach that big power with a big single turbo, which will push the torque curve higher in the RPM range.
The N54 does have hybrid twin turbos that can make around 700 ft. lbs though. Those will have an almost identical torque curve to the stock turbos. The N54 calls for a minimum 3.5 cP HTHS. At just 200% more power than that, you would need a 7 cP HTHS which not even a 10w60 provides. And the cars are reliable at that power level with the same torque curve, using a 0w40 or 5w40 oil.
