What the heck is up with the license plates? They look like they are written in some sort of alien language...
The OP did the owner a courtesy by not publishing his license numbers. They were edited out.
Mine too.Pretty car. '56 is my favorite of the 55, 56 and 57 cars.
One more for you - the 307 was introduced for the 1968 model year, but was only used in the full-size Chevys that one year. It was also available in the Nova and the Malibu, and I think last appeared in the Nova in '73.289 was a Ford engine (Studebaker also made a 289). As stated by Kernel Potter the Chevy small block started as a 265, then went to 283, 327, 350, in standard production motors. The 302 for the original 1960's Camaro Z28 had the 4" bore from the 350 and the 3" stroke crankshaft from the 283. Later they made a low performance 305 SBC and a 400 cu. in. motor for full size Impalas. In the 70's and 80's they produced some odd ball sizes like 262, 263, and 267 as "economy" engines. The hot rodded 383 is a 350 block with the crank from a 400.
Not to forget the 307.289 was a Ford engine (Studebaker also made a 289). As stated by Kernel Potter the Chevy small block started as a 265, then went to 283, 327, 350, in standard production motors. The 302 for the original 1960's Camaro Z28 had the 4" bore from the 350 and the 3" stroke crankshaft from the 283. Later they made a low performance 305 SBC and a 400 cu. in. motor for full size Impalas. In the 70's and 80's they produced some odd ball sizes like 262, 263, and 267 as "economy" engines. The hot rodded 383 is a 350 block with the crank from a 400.
The only thing not fun, is the single circuit master cylinder with 1 brake line for all four wheels, with 4 wheel drums , its not fun to drive in modern traffic. And with a single circuit, you lose all brakes with a cylinder failure or major leak, or the master cylinder fails.That looks like a fun driver. It appears to have likely been a 265 V8 car from the start based on the V emblem on the hood (and the holes for the missing top part).
I think 1967 was the switch to dual master cylinder. These cars were heavy; the drum brakes worked ok for the 1st few stops and then got hot!The only thing not fun, is the single circuit master cylinder with 1 brake line for all four wheels, with 4 wheel drums , its not fun to drive in modern traffic. And with a single circuit, you lose all brakes with a cylinder failure or major leak, or the master cylinder fails.
To drive it on the road now, i would change that master, and upgrade the front brakes to disc, especially with a v-8.
Yep. Forgot the 307.Not to forget the 307.
No, those are collector plates, so he's limited to a certain low number of miles per year. Typically, collector-plated cars are driven to car shows, swap meets, Sunday afternoons in the park, and out for ice cream (as this car had been).That's such a cool car. This guy really dailies it?
I missed that - good catch.Still has the vacuum wipers too.
They use lots of salt here, unfortunately. I would guess that the car did a few years of regular service, was parked for a long time, and now sees only summer driving.No salt used on the roads up there in winter? Or the guy only drove in the summer?
How was the rest of the vacation in Havana?I've always found daily drivers more interesting than show cars, and have usually preferred 4-doors to 2-doors. Thus, I was delighted to see this '56 Chevy 210 a few weeks ago. The original Blueflame 6 is gone, replaced by a small-block Chevy V8, probably a 350. I think the hidden fuel filler cap is very cool! Note the single-chamber master cylinder - that would be a worthwhile upgrade.
The previous owner had painted the roof silver. A complete restoration is planned by the present owner.
The interior shot appears to show a column-mounted manual shift lever.
I assume the new engine is running GM's HEI distributor, but forgot to check.
Anyway, this was a delightful find.
View attachment 69394View attachment 69395View attachment 69396View attachment 69397View attachment 69399View attachment 69401View attachment 69402
I've been told that there are lots of pre-Castro vintage cars running around with Lada drivetrains. These would provide ... leisurely ... acceleration.How was the rest of the vacation in Havana?
What's the rush? They've got no place to go.I've been told that there are lots of pre-Castro vintage cars running around with Lada drivetrains. These would provide ... leisurely ... acceleration.
Chevy cars went 12V in 1955. Vacuum wipers were still standard for a few years after that. Electric wipers became an option (not sure which year) before becoming standard.I missed that - good catch.
I'm guessing that vacuum wipers were superseded by electric when 12 V electrical systems replaced 6 V. Late 1950s?
I've driven them, and when on the roads with modern cars, down right dangerous. Was ok when everyone else had drums too.Vacuum wipers were such a weird thing. Electric was an option in 57, and they were driven by wire rope and pulleys in the dash. Vac wipers would sling the rubber inserts out during deceleration and come to a near halt on acceleration. And the leather contact surfaces in them got dry and wouldn’t move. We’d feed it a capful of brake fluid into its snout every year or so to soften them up.
speaking of drum brakes, back then they were evenly distributed, so the rears would lock before the fronts were ever near full stopping power. That, and they could be a real problem in the rain. I nearly rear-ended some of my best friends in high school as their Corolla came to an easy stop in the rain in front of me and …. we almost didn’t. I did everything I could including hand brake and L range from 45 to drag it down to stop. Hand of God abruptly stopped us 3’ off their bumper. The guys in front wanted to be mad, but the open floor of that car revealed to my passengers everything I tried, and the folks with me explained it. We are all scared by it. Flat out, discs wipe water better.
these cars had a 1000 mile maintenance interval for suspension lube and manual brake adjustment… we had the factory owners manual and shop manual. I don’t recall the oci.
Anybody remember the Chevy 267 or 262 V8’s ?One more for you - the 307 was introduced for the 1968 model year, but was only used in the full-size Chevys that one year. It was also available in the Nova and the Malibu, and I think last appeared in the Nova in '73.
The 307 had the same bore as a 283 (3.875") and used a 283 crank (with a stroke of 3.25").
In comparison, the 305, which was introduced around 1976, was an under-bored 350 (bore = 3.736", stroke = 3.48").
With a larger bore, I presume the 307 had larger valves and therefore breathed better than the 305. It also would have revved better with the shorter stroke. I don't know why Chevy didn't simply reintroduce the 307.
But the 307 had a reputation as a bit of a gas hog, whereas the 305 was pretty thrifty back in the day.
