Originally Posted By: fdcg27
You really shouldn't title threads as you did this one.
It does make you look like a troll even if you aren't.
Anyway, I don't think that either Synpower or its NAPA cousin are low quality oils.
Synpower is a Dexos licensed oil in the appropriate grades, so it can't be all that bad.
NAPA syn is very similar to Synpower by all of the VOAs I've seen, so it's probably pretty close.
I've used Synpower in the past and have a jug ready to go for some future run.
Valvoline products are pretty good generally and Maxlife is one of my favorite oils.
I have it in one of the seven rides I maintain ATM.
If you got some Synpower for two bucks a quart, then good for you.
If you don't entirely trust it, use it for a shorter run than you'd do with other syn oils. For two bucks a quart, there's be no pain in doing this since you're in conventional oil territory at that price.
And to add to that, Napa Syn is Dexos licensed as well:
http://www.centerforqa.com/dexos-brand1/
It says it on the bottle and is listed on the website.
