Valvoline Restore & Protect
It was speculated a while back that M1 HM EP used a good amount of AN. I have no idea if that's true. I'm not sure if the EP HM can clean more than the EP.
I'm of the opinion that they can clean, but limited to sludge and easier to remove deposits. I trust the Valvoline guy that worked for Infineum for 16 years when he said piston deposits are another animal and almost impossible to remove.
Does regular EP have a similar effect or is it the ester of the HM that does?
haven’t ever used the EP, always paid the extra for the EP HM (it won’t hurt anything) to clarify, talking about valvoline ep hm. i am not a fan of mobil products other than M1 0w-40 and delvac extreme.
Well in truth, it was mostly group III PP and I went a bit too long on ODI sometimes by following the OLM to 0%. I figured the OLM was calibrated to petro and I could get away with it using at least a group III. I think that was true in terms of wear, but not cleanliness. And as I've posted, I've come to believe that cleanliness is actually the more important thing in a modern engine.
VRP is the right oil at the right time for the needs of many of today's engines. IMO.
My theory is that even name brand group III synthetics run for a 5K OCI is too long leading to deposits - especially oil ring deposits . My Hyundai / Kia always receive 3.5K to 4K mile / 6 month OCI’s with M1 which is being continued with VRP . *Even if I had another brand of vehicle with a similar 5 qrt. sump , I would continue with 4K mile max / 6 month OCI . Lastly , if I decided to use another oil again (after running VRP for at least 6 OCI’s) it would be with M1 0W30 ESP. However , when VRP cleans as well as it does and offers great wear control as it does - why even consider changing back to another oil ?
Why indeed.
One reason I went HPL instead of VRP in my GX was that frankly it's a pain to yank the skidplates and stuff to swap filters and I want to push OCIs as long as I reasonably can. While VRP is excellent in wear protection and cleanliness, it hasn't been proven in long OCI usage like HPL has. If I'd be dumping VRP every 5k miles, I can go at least double that on HPL and it costs nearly the same.
So if I can get no worse protection or cleanliness with HPL at no worse cost and deal with skidplates and such half as often, I will. I think I can, so I am.
If they ever make an EP version of VRP, then the economics will be pretty compelling if indeed the oil lasts 10k+ with margin.
All we need is Euro grade R&P!!
Yep that would be the perfect oil for sure. I have to believe they are working on it. Not sure what the requirements from MB, VW, Porsche et al. are for releasing ingredient lists (like Dexos apparently requires), but that would be the only reason I can see that they don't release a Euro R&P.
I'd love a diesel spec version for my 7.3!
My diesel takes 15 quarts.
I wonder if throwing say 2 to 3 quarts of VRP in with a quality diesel spec oil (with a robust additive package), over the course of a few oil changes, would give the cleaning benefit over time without diluting what a diesel spec oil needs to accomplish?
For sure, I understand that. About 5 miles to a destination and 5 miles back is the shortest trips I take, longest is usually not more than 10 miles each way though. Only drive 2 or 3 times a week typically. 141k miles on my car (I used to drive it more). I'm hoping within 18-24 months it could make a difference.
And I respect that challenge/recommendation, I should do a little more exploring while I still live here.
Maybe you should take a couple 50 mile to 100 mile weekend run around what ever state you are in to get some miles on. Enjoy the road trip.
Give me an MB 229.5; VW502/505, LL-01 A3/B4 version in 0w-40 or 5w-40 and I'll run that in any gasoline engine on earth without worry.
Does anyone know what the requirements are for the OEM Euro specs in terms of ingredient disclosure? Could this be why they haven't pursued a Euro VRP yet (like we presume why they don't have a Dexos cert for VRP)?
You also have to consider how this chemistry would even work in a high performance engine. Curious what the threshold/capability is of the technology they're using. In other words, at what point does it struggle to clean vs leave deposits etc. How well does it handle turbo heat etc.
Remarkable oil regardless that has really proven itself to be a game changer (over used words).
Yeah I'm sure there's a lot of testing they're doing. Can't imagine what all they have to do before they're ready for a massive cap ex like launching a new product. Time will tell. They haven't launched their new ATF yet which has been in the works for a while too.
This is actually only 3x OCI totaling 15k. Several extra filters though.
Curious at what mileage you changed the intermediate filters?
I’ve read all 138 pages of this thread and I’d like to try VRP in my newly acquired 2012 CRV with 117K on the clock. There were consistent oil changes for ~50K miles, but then other dubious “holes” in its history. Judging from the crust and varnish I see in the oil fill, I’m guessing there were some extended OCI’s. I’m trying to gauge how long to run the VRP before swapping out the initial filters. This car is going to have lots of short trips and will probably only reach 3-5K miles per year. Thanks in advance!
Impressive you read the whole thread before asking a question!
With that low of mileage, I’d just change every 6 months. Loading up filters to the point they go into bypass is really rare with VRP so you’ll definitely be safe from that standpoint (changing at low mileage). You’ll also be doing a fair amount of short tripping so better to change it on a time basis due to likely fuel dilution.
When I changed mine for the first time, after 220k miles of bulk dino, I got a moderate amount of crud in the filter media. Nothing crazy but it was satisfying.
Ingredient disclosure? There is none other than hazardous materials on the SDS. Even then that can be accommodated for in regards to trade secrets.
If you mean performance requirements, then I just to take a look at the Afton Specification Handbook. There is a copy linked somewhere on this site.
