Valvoline Restore and Protect
That's funny. Valvoline has a patent on oil that cleans carbon build-up. https://www.freepatentsonline.com/y2017/0029734.html
It’s very easy to pay a lab and own the intellectual property of what they develop. This is very common in medical research. Drug companies fund research all the time in labs in universities. Anything they develop is owned by the drug company because they paid for the research.
As for me, I plan on living vicariously through Glenda W. 😄
Anxiously awaiting the results of G.W's test moving from VRP to ESP 0w-30.
If the results are as I expect, I will follow suit. Been on VRP for 3 OCI's. Likely switch to ESP. Waiting for the resuls🍿from Glenda W.
When is Glenda W. planning to release the test data results?
Use whatever grade oil you want, my only question is, do you have a way to monitor your Oil Temps?
I doubt any vehicle can monitor the oil temp at the oil control ring on the piston. Which is where the problems today are created. I would think that the flashpoint of the oil would determine the carbon disposition there but I am not sure what temp has to be reached to form the carbon from oil and fuel. I would think that most of the carbon from ignition would head out the exhaust port or stay above the compression rings.
Generic spec for SP rated oil or factual VRP NOACK ? … A NOACK of 14.9% would be pretty bad for NOACK - especially in a GDI engine !
You say this like it is a bad thing for Valvoline. Or I am misunderstanding your point?
Wow so not amazing. Just meets API spec.
Stating the Noack as <15% doesn't mean much as it could be 8% and still be "<15%". The API requirement for Noack is <15%, so they are just listing that and saying it meets the "<15%" Noack requirement. If you call Valvoline they may give the actual Noack number.
