Valvoline Restore and Protect 2003 Tahoe 5.3 228,000 miles initial observations
From what I can gather, the MM goes buy how you drive and mileage. If I drive mostly highway, the percentage decreases more slowly but as soon as we start adding in those short trips to the store, school, etc... it starts to drop more quickly. When my wife was driving the car to work every day, which is 40+ miles each way, we were changing the oil at 5k but the MM was around maybe 50-60%. Now that we have kids, do a bunch of short trips on top of her driving it to work a few days a week, I'm lucky if I can get to 7500 without it being at 0 or in the negative miles.
It does this regardless of oil used. I had Amsoil SS and HPL Premium in there and it was always the same as when we were using M1 from the dealer or Kirkland.
That's because most maintenance minders are based on an algorithm from known data the at the computer collects such as the miles driven, engine temp, engine run time and sometimes fuel burnt. I read somewhere that some high end Mercedes use an optical sensor to determine particulates in the engine oil, but they are outliers.
@WheyDowns how are things going with VRP now?
Well...funny you should ask. I was about to post a 1000 mile update.
Pulled in the garage this evening at 999.7. Let her sit for about an hour and pulled the stick. I'm down half a quart. I'll do another update at 1500. Sorry the updates are a little slow. It's my daily and I only live 5 miles from work.
Absolutely understand and thank you for the update! On the one OCI with our Mazda it did use a little oil as well, heard that it is common and settles down after a bit.
Will be interesting to see further results with short trips. I have been wondering about the cleaning effect of VRP and if there is more benefit/action in longer sustained running of the engine.
I'm really looking forward to how this plays out.
I noticed that my first change of VRP really slowed in the rate of cleaning after about 3k miles. When I drained it for fresh VRP, the cleaning kicked up again.
All that to say-- If the engine has an unknown history and high miles (and yours does), it might not be a bad idea to do an early first drain (2k-3k) on VRP and work your way back up to full OCI over the course of subsequent fills.
Three thousand mile and final update.
Ended up using 2 quarts. Generally after 3k prior to VRP I would have used 2.5 quarts.
The piston slap improvement remained through the entire interval.
Oil pressure increase remained through the interval. 2-3 psi increase overall
Possibly had an increase in fuel economy. Generally my mileage is 12.7 range this time of year and it's currently at 13.0. I guess it's possible if some compression was restored from ring carbon removal. Would have been curious what a before and after compression check would have revealed if anything. Just an observation.
Final thoughts. I haven't seen anything other than positive results in my experience and would definitely recommend giving VRP a try.
Thanks for having a great forum
