Here is a recent UOA for my 2002 Chevy Impala (4T65E transaxle). The fluid was a Castrol/GM mix after a pan drop and filter change at 50K miles (severe service interval). The lab used was Titan Laboratories. I have used them for two previous UOAs for this transmission and will include some results and comments for those UOAs to provide a more complete picture.
Total Mileage: 85K
Mileage on Fluid: 35K
Viscosity - cSt 100C: 4.5
SAE Grade - 100C: 10
Fuel Soot - % WT: 0.0
Water/Fuel Dilution/Antifreeze: None
Chromium: 0
Copper: 295
Iron: 106
Lead: 152*
Tin: 8
Aluminum: 6
Silicon: 2
Antimony: 0
Barium: 0
Boron: 94
Cadmium: 0
Calcium: 192
Magnesium: 5
Molybdenum: 0
Nickel: 0
Phosphorus: 407
Silver: 0
Sodium: 9
Titanium: 0
Zinc: 103
Maintenance Recommendations: Change oil and/or filter if not already done. Resample 1/2 normal interval to monitor system. Lead is high.
Summary of 1st UOA at 30,710 miles (factory fill):
Lead was critical (no PPM value provided)
Selected comments: Continue to follow manufacturers recommended maintenance schedule and resample at that time to monitor system condition. Critical lead is from compound used during assembly.
Summary of 2nd UOA at 50,114 miles (factory fill, before fluid and filter change at 50,668):
Selected comments: Change fluid and resample in 10,000 miles to monitor system. Lead could be from extended fluid change.
I had hoped that the trend of high lead would decrease with the transmission service at 50K. I have some immediate questions: 1) Does anyone know what the acceptable PPM is for lead in an automatic transaxle? 2) Does this level indicate extreme wear? 3) Is this a common issue for GM 4T65E transaxles? and 4) How worried should I be about the health and longevity of this tranny?
My plan is to have the fluid and filter changed this weekend (via pan drop). I am leaning towards using Valvoline MaxLife ATF due to the increased level of additives.
Any analysis and comments are welcomed. Thanks!
Total Mileage: 85K
Chromium: 0
Copper: 295
Iron: 106
Lead: 152*
Tin: 8
Aluminum: 6
Silicon: 2
Antimony: 0
Barium: 0
Boron: 94
Cadmium: 0
Calcium: 192
Magnesium: 5
Molybdenum: 0
Nickel: 0
Phosphorus: 407
Silver: 0
Sodium: 9
Titanium: 0
Zinc: 103
