TT Equalizer: MORryde CRE3000 VS Lippert Equa-Flex
California
Hi, I have a 2018 Jayco Jayflight 264BH. I'm looking to upgrade the suspension. I have narrowed down my options between the MORryde CRE3000 and Lippert Equa-Flex. If anybody has any experience with either of these or opinions on which one I should choose I would like to hear your thoughts. Thanks in advance!
Alberta
I believe our Open Range UT2504BH came with the equa-flex suspension. While I can't compare it without that, it seems to roll over expansion joints and railroad tracks quite well. Bucking is at a minimum, from my experience, so it seems to be doing its job. I think either would work well. Are you going to a wet-bolt system?
In the Garage...
May I ask why the upgrade? I tow a 2012 32 foot Passport(3220 BHWE) and have not had any issues. Is the truck getting pushed around or are you porposing often? I will be fair in saying I went from a 3/4 ton to 1 ton both of those trucks don't feel much different with the trailer hooked up other then on the hills I have to push the go pedal further. Trailer has not seemed to care either way. I have not seen these. I am going to look at them now. Thanks...I think. smile laugh ..
