From How to Lose a Beer Belly
Quote:
What’s Inside a Beer Belly?
The term itself is misleading, implying that a protruding belly is solely the result of excessive alcohol consumption.
Here’s the truth:
A pot belly is often the result of a severely blocked colon, caused by years of buildup of waste inside the body. When John Wayne died they found 60 pounds of compacted hard fecal matter stuck to the lining of his intestines.
Observational evidence suggests this is the result of excessive mucus secretions, stuck food particles, environmental toxins, constipation, etc. Removing this from the belly very often slims the beer gut down significantly. I know, I’ve done this before many times myself. To the right is a picture of what comes out. Forgive the crass picture, but you wanted advice that works, didn’t you?
So the trick is to remove the built-up waste in the colon, and then to follow a sensible diet and mild exercise routine, so that the build-up doesn’t continue.
Here’s the truth:
