I'm having a problem with my 2003 Chev Impala, 3.8L, 120K. The transmission has a very hard & premature shift when accelerating from a stopped position. It does this after it's been running a while. It seems to clear if I manually shift from 1rst thru to normal Drive. I've done 4 fluid & filter changes so the preventive maitainence is to schedule. Any thoughts? Is there a throttle position adjustment for shift changes like there is on older vehicles?
Thank you
Thank you
