Transmission fill plug won't come off! Subaru CVT
USA
I couldn't get the fill plug off the transmission. It's an 8mm allen hex key bolt. It broke my breaker bar. Subaru's torque spec is only 37 lb ft :sneaky:
I'm just glad I tried to do that first before draining the fluid :D
This is why you always take off the fill plug first--to make sure you actually can!
If I ever do get it off, I'll probably replace the fill plug with a new one, in case the plug is damaged in order to actually be removed. I think it's part #800122000. Is that right for the TR580 fill plug? :unsure:
Aluminium case steel plug? Heat gun low setting a bit of time than your 1 Lb hammer a bit on the 8mm scoket than try.
I have a can of CRC Freeze-Off. That might work.
I'd afraid to use a heat gun due to having a few electrical wires/connectors near where the fill hole is :cautious:
That can beak a small breaker bar, I am a bit surprised the 8mm hex didn't round out with that kind of force on it. Can you fit a small rattle gun in there?
Yeah I tried one of those right angle impacts on it, and it still wouldn't budge :(
use a decent impact try tightening it a little too.
back and forth a few times then out.
They are a little notorious for this.. I remember in 2016? 2017? after I broke my wrist into 7 places hanging from a breaker bar by one arm trying to get the rear diff drain plug out. was doing 1 arm pullups and it wasnt budging.
Was afraid of cracking the alum housing with an impact..
Dewalt dcf899 had it out in 5seconds.
I have a Craftsman mega torque impact wrench, which is supposedly made by Dewalt and similar to that DCF899 :D
Not sure if this is similar to your car... I would try a Knipex Cobra pliers on it. They worked for me on the Camry drain plug that I damaged.
Those things can bite! Good luck.
When I did the Mad Max SJ Forester I had to rig up my mid-torque 1/2" and do quick blips to shock it loose.
This is VERY common on the TR580 -- not sure why.
