94 Merc Sable, 3.0L, 120K miles. Transmission is not shifting out of 2nd.
This problem showed up previously, and was cured for about 2 months by disconnecting the battery and thereby resetting the computer.
Problem surfaced again a couple of days ago, and now the 'cure' only holds for a few hours before the problem shows up again.
Disconnecting the battery/depressing the brake pedal for a while/ trying the ignition cures the transmission shifting problem for a short time, so I'm positive it's not a mechanical problem.
Would replacing the computer fix this?
Any other 'easy' fixes available?
This car does not have odbcII, I believe it is odbcI. Advance auto does not have a code reader for it.
