Car : 2008 Toyota Corolla, 1.8 Engine
I am using the Toyota (Denso - Thailand) oil filters, done at the dealer using my synthetic oil. The filter called out for my auto is the 9015-YZZF2 which they use. There is also a taller, 9015-YZZF1 filter that I believe to be the same size except that it is taller ( has more filtering area??) In my engine, with 5K OCI's and synthetic oil (Pennzoil Platinum) is there any real advantage to requesting the taller 9015-YZZF1 filter? Cost is the same on teh filters so that is not an issue.
What about the TRD filter which, I believe, is the equivalent to the Denso Japan filter that is put on the car at the factory. Would it be worth the extra expense to get the TRD filter?
