The 10332 looks like a shop filter probably good for 5-7,500 mile oci. I’d personally run the 51394 be equivalent to say a fram orange can.yes it is a 2019 Toyota Corolla hatchback XSE with the M20A-FKS engine. Coming up with two Wix oil filter numbers 10332 and 51394,sigh
Okay got rid of the white whale (2012 Honda Odyssey, 178000 miles). Wife wanted a high economy car with seat heaters, no new corollas available so she selected a 2109 Toyota Corolla hatchback XSE with the M20A-FKS engine. No problem I thought just put some Valvoline EP in at next oil change and... There is no 0w16 Valvoline EP. So my question is what substitutes are there for Toyota 0w16 engine oil or is there a good online spot to order TGMO 0w16 oil. Only 0w16 oil I found on a shelve was Mobil1 AFE.
Yes and a 4967 not 4957 filter.A 2019?
You will be fine.First of the Valvoline 0w16 went in today, along with a Fram Ultra filter 4957 ( it was cheaper than getting the wix by mail). Replaced Cabin filter (ugh it was dirty) and Air filter (not bad, changed anyway).
Direct. With these engines do you have a list of recommended replacement mileages for parts (ie electric water pump)?You will be fine.
I have 200k miles of experience with this engine, accrued in a combination of Miller Cycle (higher compression ratio) and not.
I have used only 0W16 and thinner.
Stick to 5k or 7.5 k mile OCIs with the Valvoline IMO.
Top Tier fuel is not necessary with D-4S.
Sorry I do not. My plan includes changing the coolant at 120k miles (18-20 months in my case.) I will ask the dealership service advisor about the water pump at 240k miles. This is all due to my high rate of miles accrued vs time.Direct. With these engines do you have a list of recommended replacement mileages for parts (ie electric water pump)?
The laboratory completed the test on a Ford port injected 2.3-liter engine, which appears to be the Lima engine from the late 1980s. This engine has been used for testing for about 15 years and is a popular one, due to the orientation of the valves (which shows the difference in carbon deposits in just 100 hours of testing). The full report shows compares the average 34.1 milligram carbon deposit in the Top Tier fuel test to the average 660.6 mg carbon deposit in the non-Top Tier fuel test.
This driver is cognizant of Toyota's recommendations. Having tried it both ways, I have found that Top Tier is not necessary for me. Fresh fuel ie from a busy service station. Decent quality. Never less than 1/4 tank at fill up. A little Red Line SE-1. Here and there. Maybe. Of course a steady dose of Super Shell or similar would be optimum.Toyota still recommends Top Tier Gas even with the Atkinson Cycle. You can still get intake valve deposits on a port-injected engine, using non-Top Tier gas. It's more than just amount of detergents in the gas, but it's also the right detergent package to minimize deposit formation from combustion.
AAA Study Finds Drastic Differences In Gasoline Quality
Not the same: A new study proves that the type of gasoline you put in your car makes a big difference inside your engine.www.thetruthaboutcars.com
There is no 0W-10 though, next grade down is 0W-12, then 0W-8.Well next year the tree-huggers will convince the EPA to spec 0W-10 oil for climate change mitigation.
